xTaskResumeFromISR()
[Task Control]
task. h
1BaseType_t xTaskResumeFromISR( TaskHandle_t xTaskToResume );
INCLUDE_vTaskSuspend
and
INCLUDE_xTaskResumeFromISR
must be defined as 1 for this function to be available. See the RTOS Configuration documentation for more information.
A function to resume a suspended task that can be called from within an ISR.
A task that has been suspended by one of more calls to
vTaskSuspend()
will be made available for running again by a single call to
is generally considered a dangerous function because its actions are not latched. For this reason it should definitely not be used to synchronise a task with an interrupt if there is a chance that the interrupt could arrive prior to the task being suspended, and therefore the interrupt being lost. Use of a semaphore, or preferable a direct to task notification, would avoid this eventuality. A worked example that uses a direct to task notification is provided.
  • xTaskToResume
    Handle to the task being readied.
  • pdTRUE if resuming the task should result in a context switch,
  • pdFALSE otherwise. This is used by the ISR to determine if a context switch may be required following the ISR.
1TaskHandle_t xHandle;
2
3void vAFunction( void )
4{
5 // Create a task, storing the handle.
6 xTaskCreate( vTaskCode, "NAME", STACK_SIZE, NULL, tskIDLE_PRIORITY, &xHandle );
7
8 // ... Rest of code.
9}
10
11void vTaskCode( void *pvParameters )
12{
13 // The task being suspended and resumed.
14 for( ;; )
15 {
16 // ... Perform some function here.
17
18 // The task suspends itself.
19 vTaskSuspend( NULL );
20
21 // The task is now suspended, so will not reach here until the ISR resumes it.
22 }
23}
24
25void vAnExampleISR( void )
26{
27 BaseType_t xYieldRequired;
28
29 // Resume the suspended task.
30 xYieldRequired = xTaskResumeFromISR( xHandle );
31
32 // We should switch context so the ISR returns to a different task.
33 // NOTE: How this is done depends on the port you are using. Check
34 // the documentation and examples for your port.
35 portYIELD_FROM_ISR( xYieldRequired );
36}
